Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
302
Highlighted
Beginner
IPv6 anycast addresses
What are the IPv6 anycast addresses using for?, are they  some kind of broadcast?
I have a  router 2811  I'm configuring ipv6, do I need to use these addresses?
I appreciate any help.
1 ACCEPTED SOLUTION
Rising star
Good afternoon isaac mora
They are not broadcast  addressing, anycast is a network addressing and routing methodology in which datagrams from a single sender are routed to the  nearest node (such a domain ¨www.cisco.com¨) in a group of potential receivers all identified by the same destination address.
You do not to configure this feature, just configure the Unicast ipv6 addresses,
Best regards and have a nice day
Johnnatan Rodriguez Miranda
If this answer was satisfactory for you, please mark the question as Answered.
Thank you
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
1 REPLY 1
Rising star
Thank you
