09-28-2020 12:42 PM - edited 09-28-2020 06:25 PM
I have a simple working IPv6 configuration with stateless autoconfig on Dialer1 and it is working fine. My config is this:
! ipv6 unicast-routing ! ipv6 dhcp pool BVI1_DHCP import dns-server import domain-name ! interface Dialer1 description connected to Internet through VDSL mtu 1492 ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip flow ingress ip nat outside ip virtual-reassembly in encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer idle-timeout 0 dialer-group 1 no cdp enable ipv6 address autoconfig default ipv6 enable ipv6 verify unicast reverse-path ipv6 dhcp client pd ASSIGNED-PREFIX ipv6 traffic-filter IPV6IN in ppp authentication chap pap callin ppp chap hostname xxxx@myISP-A.com ppp chap password xxxxxxxxxxxxxxxxxx ppp pap sent-username xxxx@myISP-A.com password xxxxxxxxxxxxxxxxxx ppp ipcp dns request accept ! interface BVI1 mac-address b000.abcd.abcd ip address 192.168.x.x 255.255.255.0 no ip redirects no ip unreachables ip mtu 1476 ip flow ingress ip nat inside ip virtual-reassembly in ip tcp adjust-mss 1436 ipv6 address ASSIGNED-PREFIX ::/64 eui-64 ipv6 enable ipv6 nd other-config-flag ipv6 verify unicast reverse-path ipv6 dhcp server BVI1_DHCP ! ipv6 route ::/0 Dialer1 !
But I also have another stateless connection over Dialer2 which i want to use it concurrently :
! interface Dialer2 mtu 1492 ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip flow ingress ip nat outside ip virtual-reassembly in encapsulation ppp ip tcp adjust-mss 1452 dialer pool 2 dialer idle-timeout 0 dialer-group 2 no cdp enable ipv6 address FE80::ABCD:ABCD:ABCD:766C link-local ipv6 address autoconfig ipv6 enable ipv6 dhcp client pd ASSIGNED-PREFIX-Dialer2
ipv6 traffic-filter IPV6IN in ppp authentication chap pap callin ppp chap hostname xxxx@myISP-B.com ppp chap password xxxxxxxxxxxxxx ppp pap sent-username xxxx@mymyISP-B.com password xxxxxxxxxxxxxx ppp ipcp dns request accept !
As I said and before, under IPv4 everything is working fine and I am able to route specific traffic there or doing some load balancing with CEF etc. Now regarding IPv6, as you can see, there is a prefix-delegation request on Dialer1 which acquires the assigned prefix from ISP-A connection and I am able to use it with my inside interface (BVI1) ip. What I want to do is to be able to acquire the prefix AND from my ISP-B and use it in BVI1 as an additional ip:
! interface BVI1 mac-address abcd.abcd.abcd ip address 192.168.x.x 255.255.255.0 no ip redirects no ip unreachables ip mtu 1476 ip flow ingress ip nat inside ip virtual-reassembly in ip tcp adjust-mss 1436 ipv6 address ASSIGNED-PREFIX ::/64 eui-64 ipv6 address ASSIGNED-PREFIX-Dialer2 ::/64 eui-64
Unfortunately, ipv6 dhcp client pd ASSIGNED-PREFIX-Dialer2 seems it does not working for some reason. However Dialer2 is getting GUA and seems working. What I am doing wrong???
cisco#sh ipv6 int d2 Dialer2 is up, line protocol is up IPv6 is enabled, link-local address is FE80::ABCD:ABCD:ABCD:766C No Virtual link-local address(es): Stateless address autoconfig enabled Global unicast address(es): 2A02:XXX:XXX:ABCD:ABCD:ABCD:ABCD:766C, subnet is 2A02:XXX:XXX:XXXX::/64 [EUI/CAL/PRE] valid lifetime 2591878 preferred lifetime 604678 Joined group address(es): FF02::1 FF02::2 FF02::1:FFE0:766C MTU is 1492 bytes ICMP error messages limited to one every 100 milliseconds ICMP redirects are enabled ICMP unreachables are sent Input features: Common Flow Table Stile classification On Cypher Text Dialer i/f override Access List Verify Unicast Reverse-Path Common Flow Table Post VPN Stile classification On Clear Text Output features: Common Flow Table Stile Classification CCE Classification Zone based Firewall Dialer idle reset Inbound access list IPV6IN IPv6 verify source reachable-via rx, allow default 0 verification drop(s) (process), 0 (CEF) 0 suppressed verification drop(s) (process), 0 (CEF) ND DAD is enabled, number of DAD attempts: 1 ND reachable time is 30000 milliseconds (using 30000) ND advertised reachable time is 0 (unspecified) ND advertised retransmit interval is 0 (unspecified) ND router advertisements live for 1800 seconds ND advertised default router preference is Medium ND RAs are suppressed (periodic) Hosts use stateless autoconfig for addresses.
cisco#sh ipv6 general-prefix IPv6 Prefix ASSIGNED-PREFIX, acquired via DHCP PD XXXX:XXX:XXX:XXXX::/56 Valid lifetime 69931, preferred lifetime 69931 BVI1 (Address command) IPv6 Prefix ASSIGNED-PREFIX-VLAN3, acquired via DHCP PD BVI1 (Address command)
Thanks for your time
09-29-2020 12:49 AM
What is the device you are trying to configure the DHCP PD?
Here is the space for the Cisco Small Business and Cisco Business products. You may get better assistance if you post your question in the "networking discussion" section in Cisco Community.
Martin
09-29-2020 12:58 AM
Hello
Its a C886VA. Thanks for suggestion.
Leo
06-20-2021 11:06 PM
nternet Service Provider (ISP) if you can get IPv6!” ... Resources are shared between the two protocols for both Control and ... IPv6 Next Hop Is an IPv4 Mapped IPv6 Address Built from ... Prefix Delegation w/ DHCPv6 PD (RFC3633) ... Simple, stateless, automatic IPv6-in-IPv4 encap and decap functions on 6rd (CE & BR).mypantryfeedback
06-21-2021 01:49 AM
Can you give a config example of what you thought? Thanks
