07-09-2014 04:25 PM
I need to set up LAG on two ports on my cisco rv325 router.
07-09-2014 05:42 PM
The RV325 does not support LAGs. There is a new Small Business router that will be available soon, the RV130, that will have that ability, but none of the other Small Business routers support LAGs.
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
12-13-2017 07:07 PM
yes it dose the settings are available from LAN tab on gui
