Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
1375
Highlighted
Participant
NAT Question
I have two LAN devices (192.168.1.18 and 192.168.1.19) that must appear to the outside world as a single public IP address (say 100.100.100.100). I got that part down, but the problem is that I also need inbound port specific mappings.
Inbound, I would need ports 25, 3389, 80, 443 to come inbound on 100.100.100.100.100 to 192.168.1.18. This is the part I'm having trouble with configuring.
Help appreciated.
Thank you in advance.
This is on a Cisco 1800 equivalent router.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Collaborator
Re: NAT Question
You will need to add something like this:
ip nat inside source static tcp 192.168.1.18 XX interface FastEthernet0/0 XX
where "XX" is the TCP port in question and FE0/0 is the WAN inteface. Also, if you have an ACL applied to your WAN interface, you will have to allow that port in the inbound direction.
Hope this helps,
Marcos
1 REPLY 1
Collaborator
Re: NAT Question
Hope this helps,
Marcos
