03-11-2013 03:28 PM
https://supportforums.cisco.com/docs/DOC-30883
I'll appreciate any help for an IPSec VPN set up trial with RV042 please.
Many thanks in advance.
Solved! Go to Solution.
03-15-2013 05:49 PM
Hi Bay, if using a Windows computer, you may use QuickVPN for this. The one thing to note is the router you have as the gateway to the RV042. You will need to set a port forward for all IPsec services to be able to overcome the problems with the NAT.
The RV042 configuration is easy, create a user name/password and that's about it. The problem/challenge will be getting your NAT connection to allow the VPN to pass.
-Tom
Please mark answered for helpful posts
03-15-2013 05:49 PM
-Tom
04-02-2013 04:28 AM
Thanks for the reply.
I have the PPTP tunnel working ok.
I'll try the IPSec with QuickVPN, with the ADSL router towards the internet.
Will let you know how it goes, especially with NATting.
04-02-2013 07:49 AM
If you can, I'd put the ADSL router in bridge mode and use the RV042 as your main router. This will solve a lot of unnecessary steps and give you an overall cleaner network.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
