Hi guys,
I need you help on how to set up a somehow non-standard VLAN setup.
The situation is as follows:
The customer wants a WLAN set up for the company and one for the guests. Now this wouldn't be that hard if we'd be using the internal internet connection. But the WRVS4400N will be used to set up the WLANs/VLANs only.
The company uses DHCP on both of their subnets, provided by a Watchguard Firebox XTM510.
Now, what we'd like to do is set up the rear port #1 for the connection to the customer's subnet and #2 for the connection to the optional subnet for guests. The first problem is that we weren't able to set up DHCP forward for the VLAN2. It works fine on the 1st one but the 2nd only allows ENabled or DISabled, DHCP grayed out.
As a workaround it would be ok to set up the WRVS4400N providing DHCP all by itself for the guests subnet, but trying that didn't work at all.
Is there any way? Thanks in advance!
Best,
Ralph.
