338
Highlighted
Beginner
No connection after re-dial in - RV220W / VoIP
i have a problem with my RV220W. I`m using the RV220W Firewall and a Auerswald 5020 VoIP telephone system.
The WAN modem is a zyxel VDSL Bridge, the provider Deutsche Telekom Business VDSL, my VOIP provider is QSC, using a SIP Trunk product.
All works fine together, using the dynamic IP mode. Deutsche Telekom disconnects the VDSL Session every 24 hours. Thats no problem, after the re-dial in the VoIP telefone system, reconnects after one minute and I can reach again my telefones.
Now i changed from dynamic to a permanent IP adress. To use this it`s just a setting in an administration portal, so you just have to change the router "username" to dial-in. After that, Deutsche Telekom assigns the router every dial in the same IP adress, the router is still in dynamic mode.
When i use the permanent ip adress, the re-registration of the voip telefone systems fails and I can`t understand why.
I don`t change anything in the firewall settings, all ports and adresses are the same, theres no blocking.
All other internet services are working fine.
When i restart the router the next 24 hours, using a permanent ip adress the VoIP service works fine.
Do you have any ideas, why I have that problem? Are there some caches in the router that has to be deleted?
Thanks!
Best regards
Philipp
0 REPLIES 0
