PEAP authentication failure with RV120W
Ionescu Stefan
Hi all,
I have a Cisco Small bussiness RV120w and I setup the radius server , WPA2 Enterprise with a windows 2008 NPS radius server . The big problem is that the authentication fails .
This is the error that I see in event viewer / server roles / Network policy and access services :
reason-code 49 "The connection attempt did not match any connection request policy".
The radius key is matching between the server and the client .
The radius server is reachable and I don't find any routing issues .
Does anybody tested this router with this type of wireless security ? What do you suggest to do ?
Te-Kai Liu
Level 7
Level 7
RV220W release note mentioned a known issue with a workaround. RV120W likely has this known issue.
WLAN clients fail to connect to the router using WPA Enterprise or
WPA2 Enterprise. (CSCtj76452)
Work Around: To work around this issue, disable the Block Fragmentation
option in the Firewall page.
I see this is disbaled by default. The setting is the one from Firewall-> Attack Prevention - > ICSA Settings  ?
Yes, that's the option I referred to. If the issue persists, please consider contacting the Support Center to open a ticket so the issue can be further analyzed.
