Placing a Cisco RV340 behind a USG Pro 4 for IKEv2/IPsec or SSTP VPN
bw02
Evening All,
Just wondering if anyone had thoughts or advice re: the above scenario? I am currently using a USG Pro 4 which has terrible L2TP/IPsec speeds, could I purchase a Cisco RV340 and place behind the USG Pro 4 for Client VPN access (AnyConnect).
I would greatly appreciate any comments or advice.
Thank you!
Brad
Jo Kern
That will work. Anyconnect throughput is about 30Mbps on RV340. It uses SSL. So you need to forward the Anyconnect port ( typically 7443 or 8443 ) to the RV340. Works out of the box with mobile devices. Anyconnect clinet is on app or play stores.
For up to 650Mbps throughput you can use IPsec from a laptop. Anyconnect client not requried. However I have no experience on IPSec VPN passthru on the USG.
Jo
Thanks Jo - appreciate the reply!
ozo@smartbe.be
Following is the capacity and performance of rv340 regarding VPNs. You can compare these with USG 4 and if rv340 is better than USG 4, then I will suggest replace USG 4 with RV340, not put it behind USG 4.
