Port forward over dual balance doesn't work
jviramontes
Hi community,
please help me, currently I have this configuration:
Router: Cisco RV042
WAN1 WAN2
IP Address :  192.168.5.3 IP Address :  192.168.1.219
Default Gateway :  192.168.5.1 Default Gateway :  192.168.1.1
DNS :  8.8.8.8 DNS :  192.168.1.1
Dynamic DNS :  Disabled Dynamic DNS :  Disabled
I have a Static IP over WAN1 and I want to forward the ports:
1. Lan IP 192.168.2.10 -> 3389
2. Lan IP 192.168.2.120 -> 85, 8000
I did the configuration but doesn't work
Please help me
balaji.bandi
Sujoy Paria
On the screenshots it is showing that you have forwarded port number 3390 to 192.168.2.10 but on your requirement you have mentioned that you want to use port number 3389. In case you have not edited the default RDP port settings on the 192.168.2.10 PC to 3390 then please edit the ‘Port-Forwarding’ rule with port 3389.
Please make sure that you are using the default gateway on the 192.168.2.10 & 192.168.2.100 as the LAN interface IP of the RV042 Router on the same IP subnet.
Note: To make that Port-forwarding rule to work from the Internet either you need to have a Public IP on the WAN interface of the RV042 Router or the necessary ‘Port-Forwarding’ rule needs to be configure on the Router connected to the respective WAN interface of the RV042 Router.
And verify the ‘Access Rule’ on the RV042 Router to conclude that those ports are not getting blocked due to ‘Access Rule’.
