11-06-2018 09:51 AM
Hi my cisco router was running fine until I changed service provider after re entering the correct login details and dns address my router connects to my isp but don,t seem to resolve my dns.
! Last configuration change at 14:42:16 UTC Tue Jan 30 2018 by jon
version 15.2
no service pad
hostname HOME
boot-start-marker
boot-end-marker
enable secret 5 $1$qpj2$m3VpYJ1ackpYLYjVgwpBX/
aaa new-model
aaa session-id common
memory-size iomem 10
ip dhcp excluded-address 192.168.1.254
ip dhcp pool pool-one
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
domain-name tooter
dns-server 8.8.8.8 8.8.4.4 208.68.222.222 208.68.222.220
lease 7
ip domain name cisco.com
ip host media 192.168.1.89
ip host Wd-Live 192.168.1.72
ip host jon-lap-lan 192.168.1.2
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1830C298
username jon privilege 15 secret 5 $1$.YC4$TsirAWqbgmllgIJ3OpfXK.
controller VDSL 0
ip ftp username jon
ip ftp password too*****
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description LAN
ip nat inside
ip virtual-reassembly in
interface Dialer1
description Dialer interface for VDSL
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication pap chap ms-chap callin
ppp chap hostname PRO*******************
ppp chap password 0 HQ************
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server view-group cisco.com
ip dns server
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
remark access list for NAT
line con 0
no modem enable
line aux 0
line vty 0 4
password g********
transport input all
end
11-06-2018 12:46 PM
is the configuration all same was like before.
then try to ping 8.8.8.8 if that working, try nslookup and see you PC able to resolve the DNS.
may be try to use IP address in browser and see if that work to confirm DNS was the issue .
