03-29-2020 01:45 PM
Hello, I am trying to configure a site-to-site VPN between a RV325 and a RV340
The error that I am receiving is:
[g2gips1] #159: [Tunnel Authorize Fail] peer proposed key length not enabled for this connection. Attribute OAKLEY_KEY_LENGTH
I dont know how to fix it
Can someone help me?
Thank you
03-30-2020 01:46 AM
- Have a look at this thread :
https://community.cisco.com/t5/vpn/vpn-issues/td-p/356198
M.
04-02-2020 05:08 AM
Hi Sir,
I hope you are doing well.
The error which you are getting is related to authorization to connect the tunnel. Please have a reference with the below video :
https://www.youtube.com/watch?v=YgKrGjK26Tk
I would recommend you to check the configuration again on router.
Thank you.
Ajay Pareek
