10-18-2011 01:13 PM
I recently bought a new Cisco WRVS4400N router for our network which has 19 computers connected to a 24 port switch. We are currently using a D-Link router and are upgrading to the Cisco router. The problem I am having is as soon as I connect one of our servers or the 24 port switch to the Cisco router I can no longer access the internet or login on the network, I also cannot access the routers setup from either server. If I connect the router to just a stand alone computer I can access the setup and change things but as soon as I connect the server or 24 port switch everything dies (all lights are still green on the router though so everything is connected) .
Has anyone else run into this problem with this router?
Any help would be greatly appreciated.
Shawn
Solved! Go to Solution.
10-18-2011 01:31 PM
Hi Shawn,
Thank you for posting. Does the server provide DHCP for your network? If so, disable the DHCP server on the WRVS4400N before connecting it to your network.
10-18-2011 01:31 PM
Hi Shawn,
10-19-2011 01:28 PM
By disabling the DHCP Server everything seems to be working properly.
Thank you very much for your assistance.
Shawn
