Sep 30 15:42:28 2014 | VPN Log | added connection description (qknips5) |
Sep 30 15:42:28 2014 | VPN Log | listening for IKE messages |
Sep 30 15:42:28 2014 | VPN Log | forgetting secrets |
Sep 30 15:42:28 2014 | VPN Log | loading secrets from '/etc/ipsec.d/ipsec.secrets' |
Sep 30 15:42:38 2014 | VPN Log | (qknips5): deleting connection |
Sep 30 15:44:26 2014 | ACCESS_RULE | UDP 12.130.81.231:61977->192.168.150.250:33434 on eth1 |
Sep 30 15:47:14 2014 | ACCESS_RULE | UDP 192.168.150.250:4176->255.255.255.255:50799 on eth0 |
Sep 30 15:51:03 2014 | VPN Log | added connection description (grpips0) |
Sep 30 15:51:03 2014 | VPN Log | listening for IKE messages |
Sep 30 15:51:03 2014 | VPN Log | forgetting secrets |
Sep 30 15:51:03 2014 | VPN Log | loading secrets from '/etc/ipsec.d/ipsec.secrets' |
Sep 30 15:51:03 2014 | VPN Log | (grpips0): cannot initiate connection without knowing peer IP address |
Sep 30 15:51:04 2014 | System Log | client_to_gateway_g.htm is changed. |
Sep 30 15:51:31 2014 | VPN Log | added connection description (qknips5) |
Sep 30 15:51:31 2014 | VPN Log | listening for IKE messages |
Sep 30 15:51:31 2014 | VPN Log | forgetting secrets |
Sep 30 15:51:31 2014 | VPN Log | loading secrets from '/etc/ipsec.d/ipsec.secrets' |
Sep 30 15:52:23 2014 | VPN Log | (qknips5): deleting connection |
Sep 30 15:53:02 2014 | System Log | vpn_clients.htm is changed. |
Sep 30 16:07:12 2014 | VPN Log | (grpips0): deleting connection |
Sep 30 16:07:57 2014 | VPN Log | added connection description (qknips5) |
Sep 30 16:07:57 2014 | VPN Log | listening for IKE messages |
Sep 30 16:07:57 2014 | VPN Log | forgetting secrets |
Sep 30 16:07:57 2014 | VPN Log | loading secrets from '/etc/ipsec.d/ipsec.secrets' |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: initiating Quick Mode PSK+ENCRYPT+TUNNEL+PFS+AGGRESSIVE+NATTRAVERSAL to replace #155074 {using isakmp#155067} |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: [Tunnel Negotiation Info] <<< Initiator Received Quick Mode 2nd packet |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: esp_ealg_id=3-3,esp_ealg_keylen=0, key_len=192,esp_aalg_id=1-1. |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: [Tunnel Negotiation Info] Inbound SPI value = e7bd7560 |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: [Tunnel Negotiation Info] Outbound SPI value = fe527b2e |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: [Tunnel Negotiation Info] >>> Initiator Send Quick Mode 3rd packet |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: [Tunnel Negotiation Info] Quick Mode Phase 2 SA Established, IPSec Tunnel Connected |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: Dead Peer Detection (RFC 3706) enabled |
Sep 30 16:08:09 2014 | VPN Log | (g2gips0) #155075: sent QI2, IPsec SA established {ESP=>0xfe527b2e <0xe7bd7560 |
Sep 30 16:08:12 2014 | VPN Log | (qknips5): deleting connection |
Sep 30 16:08:19 2014 | VPN Log | (g2gips0) #155067: received Delete SA(0x3d614573) payload: deleting IPSEC State #155074 |
