Problem with RV016...
jorgeortegas
I have two RV016 that works very well with a VPN connection . Two both routers have two WAN Internet connections (each one). The problem is when WAN1 fails (because the Internet fails) tunnel goes down, and the only way to fix this is if I change the WAN1 cable by the WAN2. Load balancing makes it perfectly, but I need when WAN1 fails WAN2 continue providing the service. Thank you.
Steven DiStefano
Tunnel Backup is provided on the RV082 and you can see the configuration for back up tunnel in that GUI under advanced:
.  I dont think the RV016 has this feature, does it show it does in the datasheet?
Steve
josruiz
Senor Jorge: onlt the RV082 have the option to "enable back up tunnel" The RV016 or RV042 they don't have that option, therefore every time WAN1 goes down,
you have to reconfigure manually in WAN2.
