Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
761
Beginner
Problem with SRP527 and Static IP
Hi!
I have my SRP527 with dhcp and works fine.
Then i change the router to static ip 192.168.254.254.
Then i change the PC ethernet to:
IP: 192.168.254.100
SN MASK: 255.255.255.0
GW: 192.168.254.254
DNS: 192.168.254.254
After that i loose the WWW access.
I still can ping www.cisco.com, but cannot reach the web page.
Look's like the DNS Proxy stop working when i change the router from DHCP to Static IP.
Many thanks in advance.
Everyone's tags (3)
1 REPLY 1
Highlighted
Hi Jose,
Are you changing the network topology when you change address settings?  From the addressing you provide above, it looks like you are connecting the SRP behind another local router - is that correct?
Have you tried configuring a different public DNS server address (like 8.8.8.8 or something?)
Andy
