QuickVPN - RV110W behind DSL Router
kirkhalyk
Hi all,
I have a Cisco RV110W behind an Actiontek V1000H DSL router supplied by my ISP.
I'd like to be able to make use of the Cisco QuickVPN client. According to my ISP placing the Actiontek into bridge mode cannot be done.
On the Actiontek I have forwarded the following ports to my RV110W's address:
60443/tcp
4500/udp
500/udp
On the RV110W I have ensured that remote management is enabled (on port 60443).
When attempting to connect with the client (using port 60443) - I get this far:
2012/01/30 11:16:21 [STATUS]OS Version: Windows 7
2012/01/30 11:16:21 [STATUS]Windows Firewall Domain Profile Settings: ON
2012/01/30 11:16:21 [STATUS]Windows Firewall Private Profile Settings: ON
2012/01/30 11:16:21 [STATUS]One network interface detected with IP address 192.168.245.164
2012/01/30 11:16:21 [STATUS]Connecting...
2012/01/30 11:16:22 [DEBUG]Input VPN Server Address = xx.xx.xx.xx
2012/01/30 11:16:22 [STATUS]Connecting to remote gateway with IP address: xx.xx.xx.xx
2012/01/30 11:16:22 [WARNING]Server's certificate doesn't exist on your local computer.
2012/01/30 11:16:23 [WARNING]Remote gateway wasn't reached...
2012/01/30 11:16:23 [WARNING]Failed to connect.
2012/01/30 11:16:23 [WARNING]Failed to connect!
Any suggestions? Is this configuration even possible?
Thanks!
0 Replies 0
