ā03-12-2012 10:52 AM
With our old Linksys wireless router on Applications issue we can redirect port, for example:
Remote Desktop access from external pc: 201.85.X.X:1234 (appoint to our public IP and port 1234 )
Whit this we access in the Lan the private 10.1.X.X WinVista Pro machine terminal services.
I want to forward port 1234 external >>> 3389 Lan . Is possible with RV042 ??
Note: Firmware Version : v4.1.1.01 (the most recent)
Solved! Go to Solution.
ā03-14-2012 10:21 AM
To change ports source/destination you need to use the UPnP feature
that's what i use on the RV0XX
best luck
ā03-14-2012 10:45 AM
The asymmetric port forwarding config table is available at the Setup>UPnP page. Note that UPnP needs not be enabled (i.e. the UPnP checkbox can remain unchecked) to use the asymmetric port forwarding.
best luck
ā03-14-2012 10:55 AM
Nice, I'll try UPnp later. Thanks.
Done, works great. Thanks a lot.
