Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1301
Mohamed Lotfy
Beginner
Router 1841 going to rommon always
Dear All,
Please we have an issue with Router 1841, it's always going to rommon with error:
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 393216 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
flash: CompactFlash not present.
rommon 1 >
Troubleshooing:
- We have tried to reboot with >reset cmd , and also tried to change the register to 0x2102 and >reset, but still the same issue.
- We have tried to show the >dir flash and >format flash, but we get an error with no Compact Flash.
- We have replace the flash from the failure router with another working flash, but still the same issue.
- The flash that we replaced is working fine in another working router 1841.
So is that mean the router is fail totally now ? pls advice.
5 REPLIES 5
Mark Malone
Mentor
0x2102 is the correct regioster it should be set at
It sounds as though the CF section of router is faulty
can you post the full bootup porocess output from console  it will show more
Dear Brother,
this is all the bootup output:
PLD version 0x10
PLD version 0x10
rommon 1 >
As you see that's all, pls advice if the CF section of router is faulty, what's the solution of that?
it will most likely need an RMA with Cisco for a replacement
Dear Mark,
Thanks for your reply, but we have bought the router from e-bay since 3 years ago, so i think no RMA available for it.
Do do u have another tech way to solve the issue?
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
