10-15-2012 03:08 PM
Hi all,
Could someone help me to narrow down or recommend a small business router with the following requirement?
1. Support IPSec/SSL VPN for Windows 7 and XP for teleworkers
2. Support DHCP server functionality, multiple scopes for remote hosts (not directly connected hosts)
3. Support Firewall
4. Support wireless for internal users
5. Support throughput of 25 Mbps from Verizon FIOS
I am thinking 1941W or SA 520W. What do you think?
Thanks for the recommendation.
10-15-2012 03:45 PM
Unless you need Daul WAN ports or anti-virus service, RV220W is another option you can consider.
10-15-2012 08:27 PM
Thanks Tekliu. Do you know if RV220W's DHCP server can support remote hosts several hops away?
10-15-2012 08:38 PM
RV220W DHCP Server supports multiple VLANs, each of which can be mapped to an IP subnet.
