08-20-2013 10:28 AM
Hi, i have a Central RV-042 with 2 routers (another rv042 and a RV110W) conecting as a Gateway to Gateway VPN
The Central router have the net 192.168.1.0
The Other RV-042 have the net 192.168.2.0
The RV110w have 192.168.3.0 as net.
The problem is that I cannot find out how to do to make a host from the 192.168.3.0 to reach a host from the 192.168.2.0.
Any ideas?
Thank you very much!!
RV-042 VPN CENTRAL RV042 VPN RV110W
192.168.2.0 <------------------------------->192.168.1.0 <------------------------------->192.168.3.0
08-22-2013 12:27 PM
Dear Marcos,
Thank you for reaching the Small Business Support Community.
You would need to set up a new site to site VPN tunnel between the two remote sites with VPN (IPSec) Passthrough enable on the Central router, the problem you have to accomplish that is the RV110 that supports only one IPSec site to site tunnel.
I hope this answers your question and please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
08-23-2013 11:40 AM
Hello Marcos,
I found a few articles that might be helpful in configuring your VPNs. I hope you find them useful.
Basic Virtual Private Network (VPN) Configuration on the RV110W VPN Firewall
VPN Tunnel Setup on the RV016, RV042, RV042G and RV082 VPN Routers
Andrew Mayfield
