Showing results forĀ
Search instead forĀ
Did you mean:Ā
Routing between vpn rv042
marcoseloso
Hi, i have a Central RV-042 with 2 routers  (another rv042 and a RV110W) conecting as a Gateway to Gateway VPN
The Central router have the net 192.168.1.0
The Other RV-042 have the net 192.168.2.0
The RV110w have 192.168.3.0 as net.
The problem is that I cannot find out how to do to make a host from the 192.168.3.0 to reach a host from the 192.168.2.0.
Any ideas?
Thank you very much!!
RV-042                VPN                   CENTRAL RV042               VPN               RV110W
192.168.2.0 <------------------------------->192.168.1.0         <------------------------------->192.168.3.0
jeffrrod
Level 4
Level 4
Dear Marcos,
Thank you for reaching the Small Business Support Community.
You would need to set up a new site to site VPN tunnel between the two remote sites with VPN (IPSec) Passthrough enable on the Central router, the problem you have to accomplish that is the RV110 that supports only one IPSec site to site tunnel.
I hope this answers your question and please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
anmayfie
