11-27-2022 10:19 AM
Hi!
Cisco SB RV345
Firmware Version: 1.0.03.29
There is a bug on Precedence. If I change the order with precedence
WAN2 | 1 |
WAN1 | 2 |
USB1 | 3 |
USB2 | 4 |
The router continues to use WAN1 ethernet for ALL VLANs
Try with WAN1 & WAN2 enabled/disabled "Network Service Detection"
If I put on WAN1 IP with no ping reply, the router will switch the internet to WAN2.
But when I put normal IP to internet service detection, the internet goes on WAN1 again.
What's the problem? Why do I get internet over WAN1, not with WAN2?
11-27-2022 11:06 AM
if you looking for weighted preference you need to set high which one to use. as mentioned below link. ( also try to upgrade latest firmware on your device, look old I guess)
11-27-2022 11:15 AM
I'm not looking for weighted preference.
It's the latest firmware version for RV345 https://software.cisco.com/download/home/286288298/type/282465789/release/1.0.03.29
11-27-2022 11:31 AM
as per the screenshot you have selected weighted preference with dual wan.
11-27-2022 11:38 AM
Yes, and I want to use them by switching if the provider is down
11-27-2022 11:47 AM - edited 11-27-2022 11:50 AM
Are you looking active/standby ( active/active )
if you looking Active/Standby
you set WAN2 preference, and WAN1 lower preference, have you changed this config on fly? check to reboot the device and test it.
