Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2276
Alejandro Gidi
Beginner
RV016 gateway to gateway rv082 won't connect
Dear Gurus
New hardware here, requesting a bit of your knowledge
We are tryingin to setup a simple gateway to gateway  VPN
HomeA Has an RV016 with a public static IP
Local Group Security Gateway type is IP Only with the IP
Local Security Group Type is Subnet, with the local IP class 192.160.0.0
Remote Security Gateway Type: Dynamic + Email
Email address  some@emailaddress.com
Remote Security Group Type: Subnet
IP Address 192.168.1.0
IPSec Setup as default with nice password.
HomeB has an RV082 with a dynamic ADSL link
Local Group Security Gateway type is DynamicIP +Email
Local Security Group Type is Subnet, with the local IP class 192.160.1.0
Remote Security Gateway Type: IP Only
IP Address 192.168.0.0
The idea is for HomeB which has a dynamic IP, to reach HomeA, which has a static IP and connect.
But they just wont. I have not clue what's wrong, I followed the instructions, maybe i miss interpreted something.
I could share the VPN logs for both., Im getting a lot of errors there.
All pointers or suggestions are appreciated.
Im pasting here a snap of the receiving end HomeA, when i press connect on HomeB
Mar 10 11:51:41 2012VPN Log(g2gips0)[1] 187.179.136.229 #2563: responding to Quick Mode
Mar 10 11:51:41 2012VPN Log(g2gips0)[1] 187.179.136.229 #2563: [Tunnel Negotiation Info] Inbound SPI value = 3b08f98f
Mar 10 11:51:41 2012VPN Log(g2gips0)[1] 187.179.136.229 #2563: [Tunnel Negotiation Info] Outbound SPI value = fdb78f39
Mar 10 11:51:41 2012VPN Log(g2gips0)[1] 187.179.136.229 #2563: [Tunnel Negotiation Info] >>> Responder send Quick Mode 2nd packet
Mar 10 11:51:41 2012VPN Log(g2gips0)[1] 187.179.136.229 #2558: ignoring informational payload, type PAYLOAD_MALFORMED
Mar 10 11:51:51 2012VPN Log(g2gips0)[1] 187.179.136.229 #2563: discarding duplicate packet; already STATE_QUICK_R1
Mar 10 11:51:51 2012VPN Log(g2gips0)[1] 187.179.136.229 #2558: ignoring informational payload, type PAYLOAD_MALFORMED
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2562: max number of retransmissions (2) reached STATE_QUICK_R1
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2558: [Tunnel Negotiation Info] <<< Responder Received Quick Mode 1st packet
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: esp_ealg_id=2-2,esp_ealg_keylen=0, key_len=64,esp_aalg_id=1-1.
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: You should NOT use insecure ESP algorithms [ESP_DES (64)]!
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: responding to Quick Mode
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: [Tunnel Negotiation Info] Inbound SPI value = 88cbdfad
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: [Tunnel Negotiation Info] Outbound SPI value = bdcdfc69
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: [Tunnel Negotiation Info] >>> Responder send Quick Mode 2nd packet
Mar 10 11:51:56 2012VPN Log(g2gips0)[1] 187.179.136.229 #2558: ignoring informational payload, type PAYLOAD_MALFORMED
Mar 10 11:52:06 2012VPN Log(g2gips0)[1] 187.179.136.229 #2564: discarding duplicate packet; already STATE_QUICK_R1
Mar 10 11:52:06 2012VPN Log(g2gips0)[1] 187.179.136.229 #2558: ignoring informational payload, type PAYLOAD_MALFORMED
Mar 10 11:52:11 2012VPN Log(g2gips0)[1] 187.179.136.229 #2563: discarding duplicate packet; already STATE_QUICK_R1
Mar 10 11:52:11 2012VPN Log(g2gips0)[1] 187.179.136.229 #2558: ignoring informational payload, type PAYLOAD_MALFORMED
thanks
3 REPLIES 3
Alejandro Gidi
Beginner
Update:
Fixed and connected.. thanks.
If You already get an aswer for your question, I encourage you to mark the question as answered
Alejandro,
Any chance you could share your solution?  I am having the exact same problem on a tunnel between two RV082s.
