06-06-2011 08:01 PM
hi,
thanks
06-06-2011 09:36 PM
Take a look under your DHCP settings on the router (this is under LAN), you should see a field labeled "Domain", leave it blank. Also you should place DNS server entries for your clients to resolve domains out side of your network. This is also in the same area, sorry its been a while and don't remember the exact tab.
Suggested external DNS:
208.67.222.222
208.67.220.220 -- These are OpenDNS servers
8.8.8.8
8.8.4.4 -- These are Google Public DNS servers
06-07-2011 07:44 PM
under setup/network/Domain Name
i can not delete the field
once i write something inside, i can not delete it
first time i configure the router without domain name....
everithing was working fine
after i write domain name and host name fields, start to have problems
now, i can not delete any of thease fields
