Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1262
dan_truta
Beginner
rv042 dhcp dns suffix error
hi,
rv042 after configuring dhcp is giving to clients dns with appended  suffix
how can I take out append dns suffix? because when I ping server, for  example, inside lan, automatically transform in server.mydomain.com and return  error, of cours....
how can i delete host name and domain name from network setup?
all the problems appeare after i put theas fields...
thanks
2 REPLIES 2
Alejandro Gallego
Take a look under your DHCP settings on the router (this is under LAN), you should see a field labeled "Domain", leave it blank. Also you should place DNS server entries for your clients to resolve domains out side of your network. This is also in the same area, sorry its been a while and don't remember the exact tab.
Suggested external DNS:
208.67.222.222
208.67.220.220 -- These are OpenDNS servers
8.8.8.8
8.8.4.4 -- These are Google Public DNS servers
under setup/network/Domain Name
i can not delete the field
once i write something inside, i can not delete it
first time i configure the router without domain name....
everithing was working fine
after i write domain name and host name fields, start to have problems
now, i can not delete any of thease fields
