RV042 How to publish a port to a specific IP?
cruizmicronova
I want to know if is possible to publish a port of an internal server to be accesible from internet but only from a specific IP.
I know that in Setup menu exists Forwarding but it allows to publish ports to all internet no matter the source IP.
jonatrod
Level 7
Level 7
Hi Cristian, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community.
I will be more than glad to assist you with your configuration; In this case you could create a remote access vpn, what you  have to do is download the in cisco.com the QuickVpn software, install it in your computer, then create a user in your router and allow it. you can use these articles,  they are very useful
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=624
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=452
https://supportforums.cisco.com/docs/DOC-29399
Please if you have any question, please let me know an I´l l help you.
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
