04-29-2019 10:51 AM
Hi, i have running network of 25 computers, all connected with a 32 port switch. Now for 2-3 web-server i have purchased cisco RV042. All configuration was ok till the time webserver was connected directly to LAN ports of RV042 router but after connecting all computers and RV042 to the main switch no Internet on webserver. Can you please help
04-29-2019 12:36 PM
04-29-2019 02:00 PM
You need to show us your Old and new Setup
i mean where did you introuduced this new RV in the network ?
required more information to asists better.
04-29-2019 02:43 PM
my current network is like ISP link termination on RJ45 and its in switch. After that we are running pfsense which is on static IP 180.155.86.93 and Lan ip 192.168.1.5, for 25 computers. For same computers we want to use RV042 for 5-7 computers and rest will be on pfsense.
For configuration i connected RV042 to same switch WAN1, and wan IP of same range 180.155.86.91 and LAN IP 192.168.1.1 was configured and laptop was directly connected to lan port of RV042. internet working fine on laptop while its connected directly. But when i am connecting my LAN1 port directly to switch. interet via RAV042 not working i am able to ping 192.168.1.1 but not able to ping google.com or any external IP.
04-29-2019 03:22 PM
So your setup look like below :
you are terminating both WAN and LAN in to same switch ?
So WAN and Lan are different VLAN Access port ?
how does your Switch config ? ( what switch model and can you post switch config ?)
04-29-2019 03:40 PM
04-29-2019 03:23 PM
@amir4u00 hello,
04-29-2019 03:39 PM
04-30-2019 04:21 AM
04-29-2019 02:48 PM
05-14-2019 10:43 PM
We really need a diagram in order to figure out what it is you're describing.
05-15-2019 06:50 AM
If you want to plug the WAN port on the RV042 router into the switch hung off pfsense you can't plug the LAN port of the RV042 into at the same time. It breaks DHCP. You need a separate switch for the RV042 router so you can run double NAT. The RV042 router needs to use a different network than what pfsense uses for this to work. This is the best I can do without a network diagram.
