Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
2874
Beginner
RV042 / WRV200 VPN connection problem
I have a problem connecting RV042 and WRV200 with a VPN connection. I followed the instructions in WRV200 manual but the thing is not working. The problem is that RV042 and WRV200 connect but after 20 or 30 minutes WRV200 looses connection and restarts (then takes another 1-3 minutes to connect again). So I was able to establish a VPN connection but the connection is not stable. I upgraded WRV200 to the latest firmware (1.0.39) but this didn't solve the issue. I know that internet line is not an issue (I'm using 10M/10M internet) because if I ping the WAN of any of the two devices in 24hrs I get 2 or 3 lost packets.
I've searched the Cisco website for solution but didn't find any. Does anybody have a solution to this?
Thanks.
Zoran
Everyone's tags (3)
8 REPLIES 8
Frequent Contributor
Re: RV042 / WRV200 VPN connection problem
Zoran, after you did the firmware upgrade did you save your configuration, and do a factory reset of the router and reload the configuration.  This is always best practice when upgrading the firmware on a router.  What kind of internet connection do you have on the wrv210 side?
Beginner
Hi David,
There is 10M/10M internet (FTTH) on both sides. And both sides use static IPs. I'm not sure if I reset the WRV200 to factory defaults after upgrade since upgrade was done quite some months ago (the router was reset many times in this time).
Greetings,
Zoran
Yeah it should be fine.  Do you have dsl, cable or t1 on the wrv200 side?
Participant
Good Afternoon,
What firmware are you running on the RV042 side of the tunnel?
Beginner
I'm using firmware version 1.3.12.19-tm on RV042 side.
Z
Participant
Did you do a factory reset on that side?
Beginner
No I haven't reset RV042. I'll try it later next week since now I don't have remote access to it.
I'll try resetting both sides later next week and I'll let you know about the results.
Thank you for your help till now. I hope this would work.
Greetings,
Z
Beginner
Thank you for your help. The reset to factory defaults after upgrade solved the issue.
Greetings,
Zoran
