Rv042G and Sg200-50
Catalin Burla
Good day,
I am using one SG200-50 switch, with 4 ports in one VLAN1 (untagged), 6 ports in another VLAN2 (untagged), and 20 in another VLAN3 (untagged) .
I have 1 RV042 and 1 RV042G connected to SG200 : WAN1 to ports of VLAN1 (ISP1), WAN2 to ports of VLAN2 (ISP2), one LAN to ports of VLAN3 (internal network).
Spanning tree enabled on SG200.
Having this, RV042 /G does not work, does not respond to ping etc - after power on for 1-3 seconds respond to lan port and than die - loop like.
In order to make RV042 /G be online,  I removed WAN2 from SG200 and conected to another switch ( wan2 from both rv042 /G).
Question: WAN1 and WAN2 (and lan ports) are not independent "devices"?
from switch log (occurs every 3-4 days, 3-5 times per day) - witch wan1 and lan to SG200, wan2 to another switch.
13:39:06     Warning      %STP-W-PORTSTATUS: gi35: STP status Forwarding
13:39:06     Warning      %STP-W-PORTSTATUS: gi10: STP status Forwarding
13:38:36     Warning      %STP-W-PORTSTATUS: gi35: STP status Blocking
13:38:36     Warning      %STP-W-PORTSTATUS: gi10: STP status Blocking
- port 10 and 35 corespond to lan of rv042 /G (one lan to each rv042 /G)
Best regards,
Catalin Burla
7 Replies 7
Tom Watts
Hi Catalin, can you please make a diagram of how to have everything interconnecting?
The routers should have only 1 MAC address. So if you're connecting a LAN port to the switch that is common to a WAN port of the same device it should make a network loop and spanning tree should put a blocking state.
I am not able to decipher exactly what you're doing or how.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi.
Here is a diagram of my setup :
rv042 wan1 -------------- sg200 port 1
rv042 wan2 -------------- sg200 port 5
rv042 lan1 ---------------- sg200 port 11
rv042g wan1 -------------- sg200 port 2
rv042g wan2 -------------- sg200 port 6
rv042g lan1 ---------------- sg200 port 31
isp1 --------------------------sg200 port 3
isp2 --------------------------sg200 port 7
internal lan 1 ---------------sg200 port 12
internal lan 2 ---------------sg200 port 32
on sg200 :
vlan1 - port 1 2 3 4
vlan2 - port 5 6 7 8 9 10
vlan3 - port 11 - 30
vlan4 - port 31 - 48
all untagged.
on vlan1 i should have isp1 and wan1 from both routers
on vlan2 i should have isp2 and wan2 from both routers
on vlan3 i should have internal network 1
on vlan4 i should have internal network 2
Rv042 /G have (at leat display)  different  MAC Addresses for WAN1 and WAN2 (setup - network - mac address clone) and also on LAN (setup - network - under lan settings), so should not make loops.
Best regards,
Catalin
If this is your desired set up, you may disable spanning tree globally and filter the bpdu.
-Tom
Hi.
I can do some things, like using 4 switches instead of 4 vlans, but this is not my point or solution: I cannot see anything wrong in setup, but I still can't get it to work. One of equipments, router or switch , is not doing what was supposed to do.
Don't get me wrong, I have in function more than 500 rv042 /G (each with vpn tunnel to HQ) for more that 3-4 years, I know those devices. Problems started with RV042G (vpn tunnel in backup mode not get back to primary connection when available)  and becomes more sensitive when paired RV042 /G with SG200-50.
At this moment I am using 2x 5 port gigabit switch , cheap , no management , to isolate wan1 / wan2 connections. You can say this "solution" , but in reality it is not.
Best regards,
Catalin
Hi Catalin, the SG200 doesn't support multiple spanning tree or PVST. The switch is not a router, it is a switch. If you need fundamental understanding of how the switch is behaving, please read about 802.1q, 802.1d.
The purpose of 802.1d, spanning tree is to prevent network loops (you have a lot of them). 802.1d was later amended to 802.1q. 802.1q states that regardless of vlans, there will be only 1 spanning-tree instance.
The SG200 does not support MSTP (802.1s).  Therefore your only work around is to disable spanning tree and create network loops or use the switch in a more appropriate way.
Those lan segments should not be connecting to the switch if the router WAN connections are.
The difference in your statement above, an unmanaged switch doesn't do anything but provide electrical connections, it doesn't care about broadcast storms, network loops, etc.
-Tom
Hi.
All you say is correct if, a big IF, you consider RV042 /G WAN1, WAN2 and LAN a "switch". But, as long as there are 3 MAC Addresses for each port, why WAN1 and WAN2  and LAN connected into SG200 would make a network loop (first question) , and more to this , WAN1, WAN2 and LAN are going into different VLANs , why loop again(second question)?
Yes, 802.q states one spanning tree instance, but here should be none. What  VLANs  do in this case - if not to isolate traffic  (third question)?
Best regards,
Catalin
Hi Catalin, it is not really any big if because there is 1 system ID. There is a network loop because it is not spanning tree per vlan, it is spanning tree per 802.1q Vlans isolate traffic but they do not isolate spanning tree instances.
-Tom
