10-24-2019 06:08 PM
I attempted to update the firmware to v4.2.3.10_20191004 and it appears to have failed. The router is now unresponsive to admin portal. System and DMZ lights are green, Diag is fast flash Yellow and ethernet port 1 is yellow. I have tried to power cycle and also tried factory reset.
10-24-2019 06:12 PM
Hi @fmies0001
Maybe this discussion can give you some guide:
https://community.cisco.com/t5/small-business-routers/rv042g-diag-led-is-blinking/td-p/3066788
10-25-2019 04:02 AM
10-25-2019 05:45 AM
If the DIAG LED flashes quickly, that indicates there is an error, probably on the image. The mentioned firmware you tried to upgrade, just released day before yesterday. So there is not much feedback we got about this as of now.
You may open a service request with us following the below mentioned link to work on that.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
