03-06-2014 11:13 AM
Can settings exported from a RV042 be imported in a RV042G and work correctly there?
Thank you,
John
03-10-2014 11:02 AM
jbarnett77,
I don't think that this is possible. Even if it is, I would recommend creating a new configuration for the RV042G due to hardware differences. There is a "RV0xx Configuration Migration Utility" to convert the config from early hardware versions of the RV042 to the latest version 3 hardware. It works fine in some cases and sometimes does not work well at all. It is always better to create the configuration from scratch.
- Marty
03-10-2014 12:15 PM
Thank you Marty. I've decided to start from scratch (that is with a few screen shots from the old router).
John
