10-25-2012 01:36 PM
We have just setup a new RV042G firewall. The customer has multiple public IP addresses and we need to allow RDP access for at least 2 of the Public IP addresses. I only see a way to open ports for the one IP assisgned to the WAN. I temporarily did a one to one NAT for the second public IP to NAT to the private IP but that pretty much opens everything which is not ideal from a security standpoint. How can we setup multiple IP addresses on this firewall? Thanks for the help.
Solved! Go to Solution.
10-26-2012 02:44 PM
Is possible to add more that one rule to the firmware in order to provide access to different IP addresses or a complete range. Let me share with you some information on the guide me section, that could help you with the configuration.
If this answer was satisfactory for you, please mark the question as Answered.
Thank you
Diego Rodriguez
Cisco network engineer
10-26-2012 05:37 PM
On top of a one-to-one NAT rule, which maps a public IP in the WAN1 subnet to a private IP address in the LAN, you can add additional Access Rules to restrict the available services to RDP only. For example,
Allow RDP WAN1 Any [private address]
Deny AllTraffic WAN1 Any [private address]
10-26-2012 02:44 PM
Thank you
Diego Rodriguez
10-26-2012 05:37 PM
01-02-2013 08:25 PM
I am trying to find out if you can do multiple ip's or a whole subnet on the wan interface's of this router.
Did you find if this this is possible with this router and if how?
thanks
Nik
01-09-2013 09:23 AM
We were able to assign multiple IP addresses via the link above and setting up the access rules. Hope that helps.
