RV042G (router), SG200-26 (switch) vpn vlan issue
tk lam
HI,
I have a RV042G (router), SG200-26 (switch)
ISP Modem on cable have dual wan static ip
Switch have 4 Vlan
vlan1 default
vlan2 networkA
vlan3 networkB
vlan5 Modem
port (1UP,2T) management port
port 2-12 (2UP) Network A
port 13 (5UP,2T,3T) wan cable plug
port 14 (5UP,2T) go back to router wan port assign IP to network A
port 18 (5UP,3T)
port 19-26 (3UP) Network B
port25 (2UP,1T) router lan1 port connect to the switch port 25
it can separate 2 different network, if i plug a cable to port1 i can manage the switch
but if i use vpn to connect the router i wont able to ping or see the switch, but i can ping the router and all other computers are on vlan2, and vlan2 not able to go to manage the switch too or ping it
what should i change to let vpn can access to vlan1 to manage the switch, thanks
0 Replies 0
