RV082 Firmware upgrade v4.04 fails
greggbooth
I have a rv082 small business router and the current firmware will not apply. I downloaded the v4.04 firmware update and tried to apply it yet the update does not seem to work. I have downloaded it a second time and used the UPDATE FIRMWARE button to load and apply but no change.  The router is:
Serial Number : DEZ006202196 Firmware version : 2.0.0.19-tm (Feb 20 2009 15:15:20)
Any suggestions on how to update it?
Gregg
linksysinfo
Level 4
Level 4
Your trying to use the wrong firmware.  v4.04 is for Version 3 of the RV082.
you need: v2.0.2.01-tm
http://www.cisco.com/cisco/software/release.html?mdfid=282414011&softwareid=282465789&release=2.0.2.01-tm&rellifecycle=&relind=AVAILABLE&reltype=latest
Regards Simon
