09-26-2017 01:21 PM - edited 03-21-2019 10:55 AM
Hi All,
I'm trying to use an RV110W with ip filtering on inbound rules. from testing it, i find this doesn't work.
it works if i single port forward, however there is not filtering capability. just forward the port and anyone can access the device. if i use access rules, it will forward the port but IGNORE source IP filtering. i've tried various firmware 1.2.0.9, 1.2.1.4, 1.2.1.7 and all have this problem. for testing purposes, i only forward HTTP. i have nothing in the single port forward.
access rule configuration:
action - always allow
service - HTTP
status - enabled
connection type - inbound Wan- Lan
source IP range - pubic ip range
destintation ip - single private ip
log - always
it seems the source ip whether single or range is ignored. i've tried connection type - inbound Wan- DMZ with the same result. i'm using IPv4 for LAN and WAN. Wireless is turned off. Outbound is allowed.
i've factory reset for each firmware image I tried. Has anyone been able to get inbound rules to work properly?
Solved! Go to Solution.
11-21-2017 08:31 AM
09-26-2017 07:12 PM
Never mind ... think i may have solved it. anyone encountering this, make sure you add an explicit deny all rule at the end of access rules. the above access rules tells the router to allow these ips to these ports. unless the packet matches one of the above rules, the deny should stop it.
09-27-2017 06:02 PM
nope ... sorry this doesn't quite work. a deny access rule will work with single or range of ip addresses, but if you use ANY it stops the rule that had access. even if the working rule is before the deny ANY rule, it will still stop the working rule. anyone know how you're supposed to block ALL other IP addresses without killing a working rule?
11-21-2017 08:31 AM
08-17-2019 02:46 PM
Great post, thanks. Confirmed this worked for me with RV110W Wireless-N VPN Firewall and Firmware Version 1.2.2.4.
