Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
1889
Highlighted
Beginner
RV110W is replacement for WRV210. IPsec VPN tunnel between them?
I have a VPN working between two locations using WRV210s at each end. Now I'm looking to replace one 210 with a new RV110W. Can I get the two to work together? The config is quite different.
1 ACCEPTED SOLUTION
Advocate
Rod, the rv110w needs to be on the latest software release. The original release firmware did not include site to site vpn support.
http://www.cisco.com/cisco/software/release.html?mdfid=283879340&flowid=&softwareid=282487380&os=null&release=1.2.0.9&relind=null&rellifecycle=null&reltype=null
For site to site tunnel, you just need to match the settings. If you need assistance with this, you may call the support center, ensure you have access to each router configuration pages.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
4 REPLIES 4
Advocate
Hi Rod, yes.
-Tom
Beginner
Thanks for the reply, that is good news. Can you tell me how to do this please?
Advocate
-Tom
Beginner
Re: RV110W is replacement for WRV210. IPsec VPN tunnel between t
Thanks for the help. I updated the firmware but couldn't get the RV110W to establish a VPN with the WVR210. I have purchased another RV110W so it's the same router and same config options at both ends. I upgraded the firmware on it as well. The config is the same, except of course for the local and remote IP subnets being reversed. Still no VPN. I am using no-ip.com DDNS FQDN. Can someone help me get this working please? Thanks in advance!
