08-27-2012 06:22 PM
I have a VPN working between two locations using WRV210s at each end. Now I'm looking to replace one 210 with a new RV110W. Can I get the two to work together? The config is quite different.
Solved! Go to Solution.
08-28-2012 07:52 AM
Rod, the rv110w needs to be on the latest software release. The original release firmware did not include site to site vpn support.
For site to site tunnel, you just need to match the settings. If you need assistance with this, you may call the support center, ensure you have access to each router configuration pages.
-Tom
Please rate helpful posts
08-27-2012 06:25 PM
Hi Rod, yes.
-Tom
08-28-2012 12:08 AM
Thanks for the reply, that is good news. Can you tell me how to do this please?
08-28-2012 07:52 AM
-Tom
11-09-2012 11:10 PM
Thanks for the help. I updated the firmware but couldn't get the RV110W to establish a VPN with the WVR210. I have purchased another RV110W so it's the same router and same config options at both ends. I upgraded the firmware on it as well. The config is the same, except of course for the local and remote IP subnets being reversed. Still no VPN. I am using no-ip.com DDNS FQDN. Can someone help me get this working please? Thanks in advance!
