For a couple of years I'm using the rv110w wireless firewall. A few weeks ago I noticed that the WLAN bandwidth drops to 1 - 2 Mbps and only if I restart the router or switch to other WiFi channel fixes the issue. This seems to happen on regular basis amd I havent't made any changea to the router config and there are no errors in the log.
Also the WPS is disabled and I'm using only 802.11n devices.
Looking forward forsuggestions.
Alex
