Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2016
topix1993
Beginner
rv120w - fw 1.0.2.6 - wireless connection drops every hour
how can i solve this error:
Tue Nov 27 10:55:40 2012(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Tue Nov 27 10:55:45 2012(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
i have a wireless device and every 1 hours the connection drops and i must reboot the device
9 REPLIES 9
jurodri3
Beginner
Hello Mr. Serale,
According to previous post this problems is solved by updating the firmware.
On this case, the last one available for RV120w is 1.0.4.10.
Let me share with you the link to download it.
http://www.cisco.com/cisco/software/release.html?mdfid=282981372&softwareid=282487380&release=1.0.4.10&relind=AVAILABLE&rellifecycle=&reltype=latest
Also  let me share with you a tool that could help you with future  troubleshooting process. It is called Guide me, you could find it on  this forum or access it through the next link:
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?alt1=&pid=4&eroute=Super
Thank you
Diego Rodriguez
Cisco network engineer
If this answer was satisfactory for you, please mark the question as Answered.
i update the firmware to 1.0.4.10 but the problem persists
topix1993
Beginner
up
Hi Federico,
Did you resolve your problem?
I was wondering if could you share the solution with us?
Thank you
Greetings.
Johnnatan Rodríguez Miranda.
Cisco Network Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
i'm sorry but I haven't found a solution
Hi Federico, I did a search your issue, and I have  two possible solutions in order to fix your problem. First at all, did you reset to factory your device? When you upgrade your firmware device, is a recommendable do that (Always make a backup of your data).
And you can follow these two instruction in order to resolve it.
1.Under the RV220W  Go >firewall >Basic Settings>attacks Checks
   Make sure Blocker Fragmented packets is (unchecked)
2. Pnac is an 802.1x extension that applies to 802.11n connecting with EAPOL pdu through wpa/wpa2.
    Can you change the wireless radio to g only or remove the wpa security to test?
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered. Please rate post you consider useful.
Greetings,
Cisco network support engineer.
i've reset to factory the device but didn't solve the problem...
1- i try to uncheck the option "Block fragmented packets" -> didn't solve
2- i change the wireless radio to G Only -> didn't solve
i post you the log when my device disconnect (i hope this can help you to understand the solution):
ERROR:
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] secureBit not set in GTK Msg2
WARNING:
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Tue Dec 11 11:41:16 2012(GMT) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
INFORMATION:
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:00 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:01 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:02 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:03 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:04 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:05 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:06 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] key
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:07 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:08 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:09 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:10 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:11 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyNegotiating
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] Sending GTK Msg1
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] keyData
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] key
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] cipher text
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_TX(43)
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PDU_RX(44)
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] received a pdu on vap0
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] processing group key message 2
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyError
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK GK state changed from GkeyError to Idle
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK state changed from PTKINITDone to Disconnect
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] PTK state changed from Disconnect to Disconnected
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PORT_BY_MAC_DECONFIG(54)
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] NodeFree request for node : 1c:af:f7:03:1a:20
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] GK state changed from SetKeys to SetKeysDone
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] installing key to index 2
Tue Dec 11 12:07:14 2012(GMT) [rv120w][System][NTP] Looking Up time-a.timefreq.bldrdoc.gov
Tue Dec 11 12:07:16 2012(GMT) [rv120w][System][NTP] Requesting time from time-a.timefreq.bldrdoc.gov
Tue Dec 11 12:07:16 2012(GMT) [rv120w][System][NTP] Synchronized time with time-a.timefreq.bldrdoc.gov
Tue Dec 11 12:07:17 2012(GMT) [rv120w][System][NTP] Next Synchronization after 2 Hours
Tue Dec 11 12:41:11 2012(GMT) [rv120w][Local0-wireless][UDOT11] GK state changed from SetKeysDone to SetKeys
Tue Dec 11 12:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] GK state changed from SetKeys to SetKeysDone
Tue Dec 11 12:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] installing key to index 1
Tue Dec 11 12:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] key
DEBUGGING:
Tue Dec 11 11:41:12 2012(GMT) [rv120w][Local0-wireless][UDOT11] sending EAPOL pdu to PNAC...
Tue Dec 11 11:41:13 2012(GMT) [rv120w][Local0-wireless][UDOT11] sending EAPOL pdu to PNAC...
Hi Federico,
Sorry for the issues you are having with your device, in order to get a quicker answer, you can contact our technical support team and explain them your problem.
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Thanks for using our forum and sorry again for the inconveniences.
Greetings,
Stanislav Ilev
Beginner
I suppose it is already late but you can try the following:
- set Beacon to 300
- upgrade to latest firmware
- try a different wifi password (with no special characters)
- maybe set encryption to WPA (and not WPA2)
I hope there is some improvement with these.
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
