Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1370
dubwiselan
Beginner
RV120W routing through VPN problem
Hello All,
I've just set up an IPSec VPN between 2 x RV120W which are both behind other router.
Here's what we have :
RV120W #1 (192.168.1.254) --- (192.168.1.1) Office Router #1 (PUBLIC IP) --- (((Internet))) --- (PUBLIC IP) Office Router #2 (192.168.2.1) --- RV120W #2 (192.168.2.254)
It works great, tunnel is UP.
I don't use the LAN provided by RV120W's
From RV120W #2 ---> I can ping RV120W #1 (192.168.1.254) and server in LAN #1 side (192.168.1.100), perfect !
Now, I need to be able to reach the server (192.168.1.100) from a PC on LAN #2 with IP 192.168.2.50.
So, I've created au static route on Office Router #2 (192.168.2.1) because of course it doesn't know how to reach private subnet 192.168.1.x.
My static route looks like this :
192.168.1.0 / 24 (Destination network) --- 192.168.2.254 (Gateway)
...but it doesn't work, no ping.
When I do a tracert to server IP (192.168.1.100) from PC on LAN #2 (192.168.2.50), the result is :
1st jump ---> 192.168.2.1
2nd jump --> 192.168.2.254
...and it doesn't go further.
Any idea on how to make it works ?
3 REPLIES 3
dubwiselan
Beginner
Bump...
So, nobody knows if there is a solution ?
Do I need to give more details ?
jurodri3
Beginner
Hello Mr. Ian,
Please le me share with you a couple of recommendations.
In order to allow the connection between the hosts on a VPN connection please follow the next steps:
1. Go Firewall -> General -> Disable “Block WAN Request”
2. Go Firewall -> General -> Enable ”Remote Management”
3. Go VPN -> VPN Pass Through -> Verify all option be “enable”
4. Create these two firewall rules in your computer
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=4&app=search&vw=1&articleid=2922
I hope this information helps you.
Diego Rodriguez
Cisco network engineer
Thank you
*If this answer was satisfactory for you, please mark the question as Answered.*
Hello Mr Rodriguez,
Thanks for your answer but my problem is about site-to-site VPN between two RV120W, not a QuickVPN client and a RV120W.
+ points 1 / 2 & 3 are already set like this.
