RV130 configuration
sokhunov
Somebody can help me or share some links how to configure PAT on Cisco RV130 router? I read spec and its written there that RV130 supports PAT. But i couldn't find how to configure it.
Also is it possible to tunnel all traffic through VPN connection ?
riteshsh
You can configure one to one NAT by using RV130 router. Please find the link below to configure the same :
https://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=c332fc5a70fb47848b42b959862da23b_One_to_One_Network_Address_Translation__NAT__on_RV130_and_RV.xml&pid=2&respid=0&snid=6&dispid=0&cpage=search
Also you can configure and transfer the traffic using VPN in RV130 also. Please find the link below to configure the VPN :
https://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=7b8a60ab795b4ec9ae8168d600792e35_Basic_VPN_Setup_on_RV130_and_RV130W.xml&pid=2&respid=0&snid=6&dispid=0&cpage=search
 Thanks for your reply. But problems is:
For NAT i cannot use ip address that was provided me by ISP. When i type the ip address it says "IP address cannot be the same as the Router WAN IP address". What should i do ?
For VPN router allows me specify only specific IP address or range of addresses. I cannot type ip address 0.0.0.0 and mask 0.0.0.0 it gives me error "Not valid"
So how can i pass all traffic through vpn tunnel ? Not for specific IP addresses
