04-26-2016 06:28 PM
I upgraded the RV130 from 1.0.2.7 to 1.0.3.14 and right away noticed that the RV130 would disconnected from ISP for 0.5 second 2-3 times per hour. Turned on logging and can see numerous entries sets of entries: WAN Ethernet Interface is UP, Address=
07-07-2016 12:52 PM
I hope you are doing well. You probably has this information already but I would like to let you know that there is already a new firmware release 1.0.3.16 in which there are some fix that you can double check on this release notes
I hope this will be helpful for you.
12-02-2016 05:13 PM
Still happens in 1.0.3.14, 1.0.3.16, and 1.0.3.22. I went back to 1.0.2.7 and the issue does not happen.
12-07-2016 02:34 AM
Just upgraded to 1.0.3.22 and opened the can of worms.
Not working again, switching back to 1.0.2.7
