Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
333
Highlighted
RV130W port forwarding works only on VLAN 1 (default)
After 2 days of testing and switching firmware including the latest 2: 1.0.3.52 & 1.0.3.54, i cannot get port forwarding to work on an additional VLAN like my VLAN 10 (a /26 subnet).
Port forwarding only works if the internal destination is on VLAN 1.
Anyone else encountered this?
Thank you
17 REPLIES 17
Highlighted
VIP Mentor
Re: RV130W port forwarding works only on VLAN 1 (default)
Not sure if understand your requirement, port-forward should work any VLAN inside, please provide more screenshot to understand
here is configuration guide for reference :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4994-port-forwarding-on-the-rv130-and-rv130w.html
BB
*** Rate All Helpful Responses ***
Highlighted
i've added the screenshot.
So port forwarding to VLAN 10 (10.10.10.128/26) does not work
Port forwarding to VLAN 1 (default) 10.10.10.0/26 works
For clarification, i'm talking about accessing intranet host from internet.
Highlighted
VIP Mentor
Sure i can undertand out side to inside
can you post VLAN information screen shot also
BB
Highlighted
Hi Balaji,
Added screenshot
also before you ask, inter-vlan routing is enabled.
Thank you.
Highlighted
VIP Mentor
high level your config seems to be ok. last but not the least.
Couple of test to confirm :
1. Internally from VLAN 1 IP to VLAN 10 IP you were port-fording working ? YES / NO
2. The One Port-forward from Internet to LAN(VLAN 10), can you post output of  ipconfig/all (if windows ?) also netstat -na
BB
Highlighted
At Question 1: i did not do this. I am forwarding :
 WAN to VLAN10 fails
WAN to VLAN 1 works
At question2:
PS C:\Users> ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Site-local IPv6 Address . . . . . : fec0::d82c:683a:f4e9:f8d1%1
Link-local IPv6 Address . . . . . : fe80::d82c:683a:f4e9:f8d1%2
IPv4 Address. . . . . . . . . . . : 10.10.10.140
Subnet Mask . . . . . . . . . . . : 255.255.255.192
Default Gateway . . . . . . . . . : fe80::d6ad:71ff:fe5c:3f3f%2
10.10.10.129
Tunnel adapter isatap.{72BB650E-67FA-4B3C-B78B-AB13201CAF36}:
Media State . . . . . . . . . . . : Media disconnected
______________________________________________________________________________________________
Site-local IPv6 Address . . . . . : fec0::5c2b:6e85:6aea:29f9%1
Link-local IPv6 Address . . . . . : fe80::5c2b:6e85:6aea:29f9%13
IPv4 Address. . . . . . . . . . . : 10.10.10.133
Default Gateway . . . . . . . . . : fe80::d6ad:71ff:fe5c:3f3f%13
10.10.10.129
Site-local IPv6 Address . . . . . : fec0::d0af:204a:7330:7992%1
Link-local IPv6 Address . . . . . : fe80::d0af:204a:7330:7992%10
IPv4 Address. . . . . . . . . . . : 10.10.10.2
Default Gateway . . . . . . . . . : 10.10.10.1
Highlighted
idk why my last reply is not showing up.... posting again
- i only tested like this:
--- WAN to VLAN 10, this fails
---WAN to VLAN 1, this works
---i've attatched a txt file
Highlighted
VIP Mentor
ok i would like to test below one and confirm server side ok as per the config i do not see any issue here.
Try from 10.10.10.0/26 IP range any IP to try to connect what ever port you like to forward ( as per message you like to do 3389)
10.10.10.133 3389 and confirm  is this works ?
BB
Highlighted
everything works between the internal VLANs
you can see in the netstat from 10.10.10.2:
TCP 10.10.10.2:57583 10.10.10.140:3389
vlan1 host RDP on 3389 to VLAN 10 host.
this works, so i dont need internal forwarding because internal routing between vlans does this for all ports automatically
My problem is reaching a host from the outside (internet/WAN) as source
Highlighted
VIP Mentor
Since i take as confirmation from VLAN1 to VLAN 10 RDP working.
Try reboot the device after configuring port-forward , save  and reboot and let  us know if that works.
BB
Highlighted
sadly that does not make any difference, i've rebooted dozens of times, factory reset 3 times ....
it only forwards to hosts on VLAN 1 and no external access to hosts on other vlans.
Highlighted
VIP Mentor
Just to confirm make sure NAT working, try one to one NAT and test ?
If you have rights on the PC/ Server - install wireshark and check are you able to get any request coming in ?
Can you also post your outbound NAT rule screenshot
EDIT : not sure this could have issue here :
the one working config of as below :
The one not working :  ( Can you disable IPv6 here) and test other i was thinking
10.10.10.129
BB
Highlighted
i dont know what outbound NAT config is.
The only NAT options i see in the management interface of the router is the one-to--one NAT, where you need a static public IP.
I have a dynamic public IP
Highlighted
VIP Mentor
Try the one option i have suggested for I
1 Pv6 disable, - is that works ?
2. from VLAN are you able to access Internet outgoing ?
3. can you post Access Rules screenshot ?
BB
