RV130W spec and set up questions
daneince15298
Does the RV130W support gigabit speed from ISP? Is there any reason to have both a RV130W and a RV130KNa?  I am not sure how to use the USB port. Is it just for programing mobile devices? Will it work with tablets and cell phones? My purchase came with a cd, which seems not to work. It seems to take me to a website and then sit idle . thanks for your help
10/100/1000 Mbps stands for...
10 Megabits per second (Mbps)
100 Megabits per second (Mbps)
1000 Megabits per second (Mbps)
balaji.bandi
here is product specification :( Look at performance)
https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-738908.pdf
 USB port for 3G/4G modem failover or alternative primary connectivity
here is the admin guide :
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv130w/admin_guide/en/rv130w_admin_en.pdf
BB
What does 10/100/1000 mps stand for? thanksthanks for the admin guide
10/100/1000
10MB
100MB
1GB (1000MB)
BB
