RV160W
I am trying to set up a VLAN.  I follow the documentation to the letter and i can get the VLAn 192-168.2.1 up however I cannot then log into the router.  How do I set this up so the VLAN I want to create has internet access and I can still log into the router?
Thank YOu Routing, LAN Switching
balaji.bandi
Once you have changed the IP address of the device from default 192.168.1.X  to 192.168.2.X ( your PC should be the same in IP address range 192.168.2.X - try a different browser ) - if not factory reset to start again.
here is the setup guide :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5874-beginners-guide-to-initial-setup-on-rv160x-and-rv260x.html
BB
lkwallace@outlookcom
In addition to BB comments please make sure you have configured the DHCP server for this VLAN and double-check the PC NIC IP settings whether you've set them to static or dynamic.
Here is also another guide of how to set up VLANs on RV160 routers that might be helpful:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/Configuring_VLAN_Settings_on_the_RV160_and_RV260.html
Martin
