Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
1301
Beginner
RV180 ALG blocks inbound sip messages
I have a sip gateway connect to the LAN side of RV180 router which has ALG enabled.  I have no problem to make and receive calls but sometime I see the router does not forward the 'Bye' message from the VOIP service provider to the sip gateway.
Attached a wireshark capture on both WAN and LAN of RV180.
     sip gateway ip: 192.168.30.100
     RV180 WAN ip: 206.108.192.53
     VOIP provider ip: 66.237.65.67 and 65.175.129.133
In the capture frame 4292, a 'Bye' message reaches the WAN of RV180 but it never forward the 'Bye' to the sip gateway with internal ip
All settings in RV180 are default with only ALG enabled.
I tried to setup Access Rule or Port Forward but none seems to work.  Not sure if they are over-ruled by ALG?
With ALG enabled, is it possible to have individual Access Rule?  If there are conflicts between ALG and Access Rule, which has higer priority?
Everyone's tags (6)
