02-26-2013 04:57 AM
Hello community,
is it possible to use the DDNS feature (dyndns.com) behind a 2nd NAT router?
Network is as follows:
INTERNET - NAT-Router (unknown device) - Cisco RV-180 (NAT) - Clients
Kind Regard,
Michael
03-07-2013 05:04 PM
It works but not as expected, the Cisco will get on WAN side a private IP from the NAT Router and will publish that private IP in the DNS, so DDNS gets an unrouted private IP, no access possible from the Internet
07-07-2013 07:19 PM
I have this problem too...
Is there a way so that DynDNS updates to real IP address instead of NAT?
I used to have this same problem even with Windows dyndns client... so I changed to No-IP but this RV Routers don't support No-IP.
No-IP acts itself as a stunt server and updates to real IP address.
07-09-2013 07:06 AM
If you put your dyndns client in front of the rv180 or one the nat router's dmz, you should get the correct IP address. I usually use the DMZ port on a nat router when putting a vpn router behind a nat one--this solves a lot of the IP address issues for the vpn router.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
