RV180 DHCP Question
janicklas
I swear I had read somewhere that the RV180 only supported up to 50 DHCP clients before you had to statically reserve DHCP address assignments.  Is this true or am I confusing this router with another router?  Any insight would be greatly appreciated.
James
Te-Kai Liu
Level 7
Level 7
The table size for reserved DHCP addresses is 50. RV180 is supposed to be able to support up to 253 dhcp clients.
Te-Kai Liu
Level 7
Level 7
Thank you so much for your reply!
James
