09-14-2013 12:14 PM
Hi!
is it possible to do DNAT on the RV180 without SNAT? The servers in my LAN cannot see client IPs but instead only the gateway IP.
Greetings
09-15-2013 03:26 AM
further explanation of this feature ("bug"?):
- remote client: 205.251.242.54
- http server inside the LAN: 10.13.13.13
- rv180 LAN 10.13.13.10, port forwarding on port 80(http) active to 10.13.13.13
now some client connects from the internet to the RV180.
observed behaviour:
(tcpdump on the http server)
12:20:00 IP 10.13.13.10.37060 > 10.13.13.13.http: Flags [S]
the destionation address has been correctly replaced by the http servers IP. but the source address has been replaced by the routers LAN IP. this is the behaviour of a proxy, right?
expected behaviour:
12:20:00 IP 205.251.242.54.37060 > 10.13.13.13.http: Flags [S]
only the destination address should be replaced.
09-15-2013 04:23 AM
The bug probably is located in the access rules module, -> even if no SNAT is specified, it does SNAT with the source IP of the router.
Here another weird thing in the same module, i configure port forwarding to 10.13.13.13 port 80:
and then on the rules page, the ip is not listed:
This module needs work, I hope to see a firmware upgrade soon.
09-15-2013 05:16 AM
it seems firmware 1.0.3.10 fixes SNAT, IP is still not shown in the access rules.
